Message |
If I remember what I tested, anytime the wire is grounded it unlocks, when it's not connected it unlocks. (You can test that by holding the brown wire to ground, it should lock, lift it and it unlocks) The reason your single relay setup doesn't work is because your keyless entry sends a pulse to unlock, not a continuous signal. Solution: install an aftermarket actuator, or switch your relay out for a latching relay.
------------------------------------------------------------------ 1992 300ZX NA 5 Sp (Dead) 1990 300ZX NA Auto 2+2 (Dead) 1990 300ZX TT 5 Sp (Est. 400 HP) 1990 300ZX TT 5 Sp (Est. 600 HP) 2004 G35 Sport 6MT (DD) |
